RD 6000 Help
RD 6000 Help
I am trying to set up my RD 6000 for a Ultra Stick 60. It has quad flaps (four servos in the wing). I have the flaps on the gear(5)channel with a servo reverser so when I hit the gear switch they go down. I am trying to set it up so I can fly it in the "crow position". I want both of the ailerons to go up and the flaps to go down. I am also having a hard time getting the flaps to mix with the elevator. I tried C-mixing the elevator to the gear channel and I get nothing. Any help would be appreciated.
RD 6000 Help
I haven't used mine in a little bit, but I believe that for flaperons, the other aileron should be in the 6th channel. Are you sure it is in the fifth spot?
You shouldn't need a C-Mix to mix elevator and flap. There is a pre-set mix under the flap menu, or in the menu furthest to the right.
I'm not sure about the crow function though, look in the menu. There should be a function like this for sailplanes.
Kyle
Kyle
