Receiver Problem?
WV
Receiver Problem?
Yesterday at the field my plane did not respond at all when the radio was turned on.....checked the batteries, Tx and Rx were both fine, bypassed the switch, still nothing......finally, a little later I tried it again....when the antenna of the radio touched metal, the servos would chatter.....we thought it was the Tx....but when I got home, I tried a different Tx on the same channel.....the result was the same, the servos chattered when the antenna was touched to metal....but no control whatsoever.......do you guys think this is a bad reciever, or could it just be the rx crystal? I haven't tried changing the crystal because the only other one I have on the same channel is a Hitec...the one with the problem is an Airtronics. I would appreciate any insight on this.....
Mike
Mike
My Feedback: (16)
Receiver Problem?
Sounds like either the RX or crystal to me. I don't know of any way to test a crystal. Maybe you could borrow a crystal from someone as a test.
Good luck!
Mike
Good luck!
Mike
My Feedback: (53)
Receiver Problem?
I had something similar happen.. was flying along and rolled on the back and then .. nothing. The plane would not respond. After the crash we checked the batteries.. they were good. I exchanged crystals.. RX would not work with the original or the replacement. Rx was sent back to JR for further investigation. The radio was new in the spring. My guess is that the Rx went and took the crystal out in the crash.. ps when the servo was plugged into the Rx they would jump then nothing.
WV
Receiver Problem?
Hmmmmm.....so far it's sounding like I may have to try a new crystal.......the reciever is an older airtronics with the old-style connectors...does anybody know if new airtronics crystals will work in it?
Also, a friend of mine has an extra receiver that is just like mine.....so I'm going to try that also....
Mike
Mike
VA
Receiver Problem?
Glowplug: I heard of a guy who uses channel 40 and 41 crystals in his Futaba T6XAS (factory tuned to ch 40). Of course WE would never do this!
Whenever HE forgets, and leaves the the channel 40 transmitter crystal installed while trying to control his channel 41 plane, it acts just like yours.
Hope this helps...
Fred
VA
Hope this helps...
Fred
VA
WV
Receiver Problem?
Fred....sounds like YOU'VE been there when HE has done this?? he he he.
Well, in that case....it sounds like a crystal.....I'll have to try that first. Thanks
Mike
Mike
