Royal Evo 12 channel selection problem!
My Feedback: (19)
I have a Evo 12 with synth module and scanner. Ever since installing the scanner module the radio will not allow me to change channels!!! took the scanner module out and the radio still will not allow me to change channels. Has anyone else encountered this problem???
Thanks;
Dan
Thanks;
Dan
RE: Royal Evo 12 channel selection problem!
Hi Dan
Don't want to ask the obvious, you are holding down thw setup(spanner) button when you switch on?
Tony
Tony
My Feedback: (19)
yep...
Like I said it worked fine prior to installing the scanner module.....ever since, I cannot get it to change from channel 11...other than that the radio still works fine.
ORIGINAL: Tony abw60
Hi Dan
Tony
Hi Dan
Tony
I think it might well be a faulty scanner.
If i'm not mistaken there is a mention of channel 11 being a problem on another forum (RCgroup) massive threads on there about the Evo, some one on there may be able to help better than me.
Not long had mine so I am still learning it. But what a great radio.
Good luck hope you get it sorted
Tony
Tony
My Feedback: (19)
this afternoon I tried swapping the the synth module with one from another Evo.....works just fine....put my synth module back in...stuck on ch11....so it looks like it is a synth module problem.
thanks;
Dan
thanks;
Dan
