Futaba Receivers
Old 10-01-2002, 03:50 AM
Default Futaba Receivers
Just bought a futaba FP-R148DF Can someone tell me what is the difference between this and my old FP-R127DF?
Old 10-01-2002, 08:56 AM
Hi, Bruce!
The R148DF is a higher quality, micro size receiver which supports 8 servos plus the battery (using a y-harness to your lowest drain servo). You should expect to see a slight increase in ground range with an R148 over an R127.
Old 10-01-2002, 01:16 PM
Default Thanks
Thanks AnnMarie, I appreciate your time.
Bruce
Old 10-02-2002, 02:37 PM
AnnMarie,
Can you expand on the y-harness thing. Sorry I'm still trying to learn all of these tips.
Chris
Old 10-02-2002, 05:45 PM
Sure, Chris. Your battery can be plugged into any port on the receiver (except the DSC port, if any). Ifyou're using 8 servos on a mini receiver htat has only 8 ports, you use a y-harness to plug the battery and the throttle servo into and then plug that Y into the throttle channel. This puts the battery and the least drain servo into a single port together.
Old 10-03-2002, 02:05 AM
My Feedback: (12)
Nice to know.
Old 01-31-2003, 04:55 AM
Answered my question about the battery myself.
Fly fast, fly low
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
