no signal
no signal
any one help i have koyosho 1/10 scale rally car ijust built and it has no radio rangewell about 10 meters and loses signal it has brand new batterys
CA
RE: no signal
Did you cut or coil the receiver antenna? Are you not using a transmitter and receiver from the same manufacturer? Did you change the crystals in both the transmitter and receiver? Answering yes to any of these questions could be the cause of your problem.
