Digital servo fail safe w/o programmer
Old 10-03-2002, 12:54 AM
My Feedback: (31)
furloughed ual's Avatar
Default Digital servo fail safe w/o programmer
Considering the Hitec digitals (I have read the numerous posts regarding the lockups). I have a few questions I couldn't find the answers to....
1. Using Futaba 8U with PCM, can I set a servo failsafe position?
2. Can I subtrim the digital to center the arm?
3. Can I use the 8u transmitter to reverse one servo (for dual elevator servos) by program mixes ( I can with analog servos)
4. I assume end point and ATV work the same as analog servos?
All above questions relate to NOT using the Hitec programmer. Thanks....
Old 10-03-2002, 01:44 PM
My Feedback: (31)
Default Re: Digital servo fail safe w/o programmer
Originally posted by furloughed ual
1. Using Futaba 8U with PCM, can I set a servo failsafe position? Yes, use the failsafe settings within the TX. Factory Hitec default is FAILSAFE "off".
2. Can I subtrim the digital to center the arm? Yes. Same as analog.
Yes, use the servo reverse screen in the TX.
4. I assume end point and ATV work the same as analog servos? Correct.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
