Range check
Range check
What is the proper method and distance for a range check? I check my system with the antenna down and at a distance of at least a hundred feet. Do you face the plane or turn the transmitter away from the plane. I can get much further than 100 ft facing the plane.
My Feedback: (16)
GA
Range check
Their are several ways to do it depending on your equipment type. The easiest is JR's procedure for PCM which also works for Futaba PCM. http://www.horizonhobby.com/articles/1079.asp
