Futaba Receiver and Jittery Servos
MO
I have a Futaba FP-R127DF that I have four s3003 servos attached to. When I move the elevator and aileron stick the other two servos jitter. The battery is charged, the Rx antenna is uncoiled, and I can't think of what makes my receiver jitter. I have thought of just replacing it because I know a lot of folks won't touch a receiver after it's been repaired. I'm looking for some ideas. Anything helps.
Thanks.
Thanks.
NE
RE: Futaba Receiver and Jittery Servos
Almost sounds like something is out of spec on either the TX or thr RX. I've seen what you described happen before. Probably should send in the suspect unit(s) for repair.
MO
I know the radio is fine. I've got a 6EXA and I had it serviced this Spring. I've also used it on three other models/receivers and don't have any jitter problems.
Check the battery wiring and switch. If you can, plug the battery directly into the reciever bypassing the switch and see if the problem continues. A poor switch or to small a gage wiring can cause these symptoms.
MO
I originally started by just plugging the battery into the receiver. Same difference. I don't usually use a switch until I'm ready to start final testing anyway, but I understand what you're saying.
MO
I recharged my battery just for grins an giggles and now the jitters are gone. I'm beginning to think that the battery is faulty. I think I might just toss it into the recycle heap at work. I've got a new Hydrimax on the way to replace this one, but I wanted to know if anybody still thinks I should replace the receiver.
Thanks.
Thanks.
