hitec 945 problem
hitec 945 problem
hi,
i have a hitec 945 on my rudder. when i move the rudder back and forth and when i leave the stick the rudder come to the center and starts to fluter. what gives? I'm using a 9 CAP with the receiver that it comes with. i've changed the servo and it still happens. my receiver is quite new and never had this problem before. all this is on the MOJO 60 with Saito 91 and 6v battery.
thanks.
thanks.
My Feedback: (41)
RE: hitec 945 problem
This is more than likely slop in your linkage. The momentum of the rudder creates an ocillation about the center point. It just bounces back and forth in the slop. Tighten it up and it will likely go away. If the servo has a lot of slop in it, that could be the problem too. Maybe the gears need replacing.
My Feedback: (7)
ORIGINAL: tiktock
hi,
thanks.
hi,
thanks.
