compatable radio systems
Hi,
I wonder if anyone can tell me what all radio systems (if any) are compatable with another and if so, to what degree? Futaba with Hi-Tech, Hi-Tech with JR... etc..
RE: compatable radio systems
In the US Futaba and Hitec use negative shift while Airtronics and JR use positive shift. Some of the Hitec transmitters can be set for either shift (the Prism, Eclipse and Optic 6) and maybe there are other brands that can be set for either shift. If you get into PCM, there is no compatability so you must have the same brand transmitter and receiver if going PCM.
