futaba
My Feedback: (29)
futaba
have a futaba system in a siq 1/4 cub the system works fine but the airleons have a problem the left servo powers up and centers but has no power the other one is perfect i can move it up and down easy servo is on a hd 24 lead and into a y have switch it around with no luck thanks for any ideals or help frank
My Feedback: (9)
RE: futaba
I assume you are running a " y " to channel 1 on the receiver which drives both of the aileron servos. if you can switch sides of the "y" to the aileron servos and the left servo still fails then the problem is almost assuredly in the servo itself or maybe the extension from the "y" to the aileron servo connector.
What happens if you plug a new or known good servo into the "y" along with the right side aileron servo?
