radio modules
Old 10-22-2005, 11:33 AM
nate1001
nate1001's Avatar
Default radio modules
If I buy a pcm radio, jr9303, do I need a different module to switch to fm (ppm) on the same channel? The jr radio I have now is selectable in the menu but it doesn't have a module. just want to make sure before I buy it.
Old 10-22-2005, 01:38 PM
bhanley
Default RE: radio modules
You won't need an additional module. The 9303 can transmit either PCM or PPM with the same module. The modulation is selectable just as for your present radio.
Old 10-22-2005, 05:15 PM
BaronSchwab
The only thing that a module does is change you transmitting frequency. You radio takes care of PPM and PCM depending on which mode you chose to Xmit on.
Old 10-22-2005, 07:18 PM
nate1001
nate1001's Avatar
thanks for the help
Old 10-26-2005, 12:59 PM
hueyman
excuse my ignorance but do you mean you have to have a module installed that operates on desired frequency (35mhz, 72mhz, etc...)? tx will not operate without a module correct?
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
