Carbon Rod interference
TX
I need to have two carbon rods that will cross, they are close but do not touch. If in the case of vibration will two carbon rods rubbing cause any interference like two metal rods?
My Feedback: (10)
GA
Since nobody can possibly say with certainty what it will do in your particular application,
why not take all measures necessary to make sure it doesn't happen in the first place?
This could take the form of building guides near where they cross, to hold them off each other,
or it could be as simple as covering one of the rods with heat shrink tubing or monokote
Always better to be safe than sorry
TX
I was really asking the question from an RF point of view though. You always hear about metal but I don’t believe I have ever heard of carbon rods causing interference.
Carbon fiber rods do not cause interference. However you mentioned the possibility of them rubbing each other, which opens up an entirely new question....I do not know if they would. That is why I would eliminate any possibility of the rubbing.
Vince
Vince
My Feedback: (12)
MO
Like anything else if they where allowed to rub together they could fail do everything you can to minimize this potential failure point. Carbon rods do not cause radio interference.
