Spektrum radio
My Feedback: (168)
FL
RE: Spektrum radio
If I may interject a comment here....
Transmitters must be narrow band so as to not interefere with receivers on adjacent channels. Receivers must be also narrow band, so as to REJECT legal narrow band signals from adjacent channel transmitters.
Either situation could cause a loss of control, and.......well, I'm sure you get the picture.
Happy Holidays.
Jim
Happy Holidays.
Jim
My Feedback: (7)
RE: Spektrum radio
ORIGINAL: daven
Yes, wide band receivers are not allowed at our field.
In todays "sue happy" world you have to cover your back side.
The point I was trying to make of you all is before you act, know what the heck you are talking about. Knee jerk reaction is not needed.
And BTW, if I came to your field, how would you know if I was wide band?
VA
RE: Spektrum radio
Just for my own curiosity, how come 3 channel spectrum system for RC cars are far more expensive than 6 ch radio for park fliers, $350 vs. $200?
Does anyone have answers?
#32
RE: Spektrum radio
The little SPEKTRUM works likea champ here at 4500 ft elevation -in a "bowl" surrounded by mountains with various antenna towers feeding the valley.
Once I figured out the sequences for running thru the mixes / ATV/ Expo /etc- I setup my model on two aileron servos and flew it in our park.
It is a great setup and only the absent rudder expo was any issue.
So -now I will get more rx for my other foamies and sell off my 72.00 stuff.
I fly HAM on all my gas powered stuff as the plethora of newbie "I don't know/care" flyers on 72-is just to spooky for me.
#33
RE: Spektrum radio
This new technology for flyers sounds great.
One point here though.
We are all having trouble with models being frequently shot down. 4 models last Friday. These were NOT wrong thumbs.
So what's the beef with placing the Spectrum system in a larger model?
Can't see that it increases the risk at all, you may still dive in, but so what?
Probability is that you would have been shot down in any case!
#34
RE: Spektrum radio
Here is another model with the Spektrum-note antenna placement!
As long as you are a good flyer who can and will stay in close -no problem
problem is most novices just follow the plane around and at very high -long distances -so the radio is NOT recommended for any but small models which must be in close .
I can see no problem tho with a good 3D model flown in at under 1000ft distances -
I am not speaking for the manufacturer!
if this stuff is all new to you -- stick with the recommendations!
#35
CA
RE: Spektrum radio
I've heard hat this 2.4 ghz system is supposed to be a line of sight. But Obviously it isn't since we put the Rx inside of airplanes made of foam, balsa, fiberglass, plastic covering, etc.
Can someone give some info on what density of material would become a blocking factor? I usually hear that fiberglass is transparent to radio waves. Some flyers have no problem with their antenna inside carbon fuselages, others put them outside.
Any thoughts?
Any thoughts?
#36
RE: Spektrum radio
Yes, 2.4 GHz is line of sight, but for that matter so is 72 MHz as far as RC is concerned. Line of sight means that the propagation path is a straight line between the transmitting antenna and the receiving antenna. Line of sight does not follow the curvature of the earch, bounce off the ionosphere, get ducted in the troposphere, etc, etc.
Balsa and thin plastic coverings are virtually transparent to 2.4 GHz. Any thin non-conductive material will not be a problem. Thicker non-conductive materials are not a problem if they are low density (e.g. balsa). Conductive materials such as metalized coverings and carbon fiber would be a problem.
It seems to me that they did a real nice job with the Spectrum. It appears they have a basic polarization diviersity setup with two receive antennas. Ideally those antennas should be oriented perpendicular to one another.
#37
My Feedback: (10)
RE: Spektrum radio
Antenna loading depends on how close the antenna is to the material and the type of material. Foam, fiberglass, etc can all have an effect on an antenna's usable frequency and the signal degradation through the aircraft. 2.4GHz has a higher path loss than 72 MHz and is MUCH more directional. I beleive this is why they have essentially placed two receivers inside the receiver and placed them out of phase with each other. With a rapidly varying attitude of an aircraft, this is pretty important.
Michael
Michael
#39
My Feedback: (10)
RE: Spektrum radio
The wavelength of 2.4GHz is much shorter than 72MHz, therefore you will be flying through many more antenna pattern nulls as the aircraft moves along. You will always have a direct signal in line of sight, and constructive or deconstructive signals based on the phasing of the signals and where they reflect off of other objects. Picture a radiowave as a standing sine wave. The 2.4GHz repeats far more often than 72MHz, therefore you will fly through possibilities of nulls more often.
Yes, monopole antennas exhibit the same antenna patterns, i.e. a donut. They radiate outwards. The frequency/wavelength correlation are what give the nulls. Your transmitter antenna is bouncing radiowaves off of anything within the signal's propagation distance.
A directional antenna would not be of any use on an aircraft, unless one needed gain and had the ability to track the aircraft.
FWIW, our club is pretty large and it was decided that we are going to make up a set of frequency pins that simply say 2.4GHz, spread spectrum . Since there is a system in place where a member must put up a club card in place of the pin, we will at least know what frequency the pilot is flying on while he is out on the flightline.
Michael
Michael
#40
My Feedback: (162)
RE: Spektrum radio
I've heard that there are growing concerns in the ama concerning the use of these radios in larger models. They're concerned that people are exceding the designer specs by putting them in larger models than park fliers and that it could cause more incidents!!! We probably will see the ama issue some kind of statement although I don't know if they will deny insurance. I look for them to put the issue more to the clubs to enforce, police?
The only limitation spektrum lists is the range. Personally, I love the radio and 3,000 feet (take your car and drive 1/2 mile from an object, stop and see how far that really is) is a LONG WAYS AWAY!! Following their logic, the closer the plane gets to the transmitter the more reliable it's going to get so the only chance of loss, other than dumb thumb, is flying to far away. I fly jets and 40% planes and I don't fly them that far away!
I think a module with the same range or slightly better would be more than adequate!! Can't wait!!!
#41
RE: Spektrum radio
In actual practice -as noted -the radio is grrrrreat!
I have had kicking around -for years a lovely small scale Taylor Cub -built years back by an old friend - It was powered by a .049 glo and had an old radio etc..
I stripped it out fitted the new Spektrum and a 370 electric motor.
I can fly it as far as I can see to control it .
Frankly -I think I could fly any of my big gassers on it also - But I will NOT do that- I fly in reasonably close
in the monkey see monkey do approach seen today -I am certain someone else would folow suite and fly their model out of range.
#42
RE: Spektrum radio
how are all the features on this thing. I am debating over this or the optic 6 and don't really know what to do. will this work for sail planes. also can you put the DR and EXpo for both Ailerons and elevator on one switch? it's nice to be able to get to the "Slow" controls quick if i'm about to eat it.
#43
RE: Spektrum radio
ORIGINAL: Airbike
Hey Capt,
I was/am tempted to install the Spektrum Rx into my electric pylon plane (30" wing span, 16oz all up weight, these specs seem to say this is a parkflyer, except that is was radared at over 120mph doing level laps, prob 140+ in a dive)
But I think I will wait a while for more information from all of the users to see if there are any hidden gremlins. Meanwhile, I'll continue to check out its performance in the Fliton Mini Extra.
I would suppose that Horizon specified this system for parkflyers and micro-helis to limit their liability exposure while the technology matured a little. At the same time, they've been able to be the "First to Market" to grab a significant market share even if others come out with similar systems, perhaps based on something just different enough not to infringe on any patents.
Oh and about that pylon racer; I'm waiting for a replacement now since it took a glitch (electron 6 Rx) when it was low and banked hard and at about 100-120mph. Nice puff of dirt it threw up!!![:@]
Hey Capt,
#44
CA
RE: Spektrum radio
Hi Firegarden, no need to worry about the range of the Spektrum in a Fliton Mini Extra, I've flown my Mini extra farther than normal until it was just a speck and had no range problems. So far, with another Rx on my Foamy Extra, both planes have flown way beyond normal comfortable visual range and I haven't had a single glitch yet.
I was at the AMA Convention/Show here in Southern Calif. yesterday and spoke with a Spektrum rep. I was concerned about the speed of a small pylon racer and any possible Rx orientation problems, but was reassured than as long as I stay close in (like a park flyer) the Spektrum would be fine.
and sorry, I don't have an Optic 6 Tx, I was using an Electron 6 Rx with my JR9303 Tx when my little electric pylon plane took a dirt nap[]
#45
TX
RE: Spektrum radio
Hey guys.
Am relatively new to RC flight, currently have an RTF, and am looking at plane number 2 now. That will likely be a slow stick, but I want to go ahead and get a versatile radio that I can use for a long time with many different planes. I'm kind of a geek, so the 2.4ghz latest and greatest is pretty appealing, but I don't understand what all the features of the radio are, so it's hard for me to judge this thing against a more typical 72mhz in the same price range. What do you guys think--is the Spektrum something that's a good radio to get and grow with, or am I going to be running into problems with a lack of some key feature, or flying fields banning me?
#46
My Feedback: (21)
CA
RE: Spektrum radio
Just wanted to add my 2 cents. I full range checked a friends DX6 today at the field. I drove about 2300ft away and the thing was flawless. No noise and fully functional. I put the DX6 in the bottom of my VW bus and it still freaking worked great. The whole time I was talking to my friend on my cell phone to confirm operation of the plane. The metal body of the VW bus did not kill the signal. By comparison both my Futaba R127 had significant gitter at the same distance and the Polks Hobby receivers did not work at all. Both the Seeker 6 and the Sekker II from polks have been the worst receivers I have ever seen. I just sent them back for the 3rd time with a note stating it's the 3rd time and am hoping they will finally send me a pair of receivers that give me better than 2300ft range. The Polks Tracker III transmitter has been working great for the last 5 hours of flight time I have on it. It appears to have good range. Futaba specs their R127 at 6000ft+. I'm gonna have to send my R127's back for tuning. One more thing. My cheap GWS 8ch dual conversion was the best receiver I had of my 72mHz receivers. It was functional and glitch free to 2300ft. Same as the DX6.
I'm very impressed with the DX6.
Jason Keiter Vacaville, CA
#47
RE: Spektrum radio
Eventually they'll have a spektrum module for my Futaba 9chp, but for now I have my T-rex450 and Caliber 30 set-up on the spektrum system. I keep both heli's within a 200 yard range, and hav'nt noticed a single glitch. They're both CCPM and the dx6 is ccpm capable. It's a great system for the money, Tx,Rx, and four micro servos for a couple hundred bucks.
#48
My Feedback: (21)
CA
RE: Spektrum radio
1.03 mile or 5430ft line of site range worked flawlessly on my friends Spektrum RD6. I was talking to him on the cell phone the whole time. By comparison my Polks Tracker III with a GWS receiver had no functionality on ch58 nor did another plane on ch50 with the Tracker III. I'm totally blown away. I cannot wait for them to make an 8ch or bigger with digital trims and allow gas planes. If they could do it for $300 with receiver and one servo I'm sold. If anyone else owns an RD6 I suggest you find an area with a good line of site range and have a freind help you do a range check to see just how far you can get. I used my GPS for distance measurment. There was a huge mound of dirt where I was and I did lose signal when I went behind it. The dirt pile was about 40ft high and around 200ft thick.
