optic 6 battery life?
Old 12-09-2005, 03:52 PM
Cambo
Cambo's Avatar
Default optic 6 battery life?
How long should this thing stay on after a full charge. Mine seems to burn through the battery relativly quickly while i am getting one of my planes ready to fly.
Old 12-10-2005, 06:06 PM
Ernie Misner
Ernie Misner's Avatar
Default RE: optic 6 battery life?
Most transmitters still come with 600mah or so nicads I think. Pull the battery cover off and see if it says what kind they are. These standard batteries usually are good for at least half or more of a full days flying. If you want to go all day without even thinking about it, replace the standard pack with 1650 or so Nimh batteries. If your radio is still new, the batteries will get stronger after a couple of charge and use cycles.
Ernie
Old 12-13-2005, 11:05 PM
aeajr
aeajr's Avatar
If you have a single channel module, your current draw is probably about 180 mah so a 700 mah battery should give you about 2 hours + some.
If you have the Spectra module, take an hour off that.
I have a 700 mah and a 2000 mah pack for each of my computer radios.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
