Will These Servos Work On This Plane?
Old 12-19-2005, 02:47 PM
BULLSEYE
Default Will These Servos Work On This Plane?
I was wondering if the servo below:
http://servocity.com/html/hs-81_micro.html
Would work on this plane below:
http://www2.towerhobbies.com/cgi-bin...&I=LXRF43&P=ML
I didn't know if they would handle the load.
Jose (aka Bullseye)
Old 12-19-2005, 05:52 PM
carrellh
carrellh's Avatar
Default RE: Will These Servos Work On This Plane?
Short answer: No
The plane calls for 'standard' servos.
Old 12-20-2005, 06:16 AM
3D Joy
3D Joy's Avatar
Servos are a bit small but they are known to be rugged. Torque and speed are there but not sure if the servo itself can hold up. Personnaly I would be tempted to try it, I am not the guy that flies wide open all the time. At least one on each aileron though.
Old 12-20-2005, 12:12 PM
MikeMayberry
MikeMayberry's Avatar
The metal geared versions would work fine.
Mike.
Old 12-20-2005, 12:16 PM
daven
What engine are you putting on the plane? I would be hesitant at best to use those servos, and would go with the Hitec 225 over the smaller 81 series, especially if you are looking at large surface throws and violent aerobatics.
Old 12-20-2005, 01:42 PM
BULLSEYE
I will be using the Saito 40a to keep the weight down. I guess I will use the HS-81 for the throttle only.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
