Transmitter age JR 8103
Old 12-22-2005, 11:27 AM
nelnet
Default Transmitter age JR 8103
I have a jr 8103 transmitter with a serial number of 0638278. does anyone have an approximate age of this radio? I bought the radio used and don't have a manual. Are there any maintenance issues I should be concerned with?
Old 12-22-2005, 12:31 PM
bruce88123
Default RE: Transmitter age JR 8103
Can't give you a direct answer but one place you can ask is in this forum:
http://www.rcuniverse.com/forum/forumid_116/tt.htm
Old 12-22-2005, 12:40 PM
bruce88123
You didn't give your exact model. See if this manual helps:
http://www.jrradios.com/ProdInfo/Fil...612-manual.pdf
If not correct, you should be able to use this URL as a basis for a search.
Good luck.
Old 12-22-2005, 03:02 PM
Ed_Moorman
Ed_Moorman's Avatar
If it has digital trims except for throttle, it's one of the newer ones. If they are all manual, it is an older model, but all the other functions are the same. With the manual model, you'll need to use Trim Memory after flying when you have changed your trim.
Here's the URL for the pdf manual. [link=http://www.horizonhobby.com/ProdInfo/Files/jrp8612-manual.pdf]JR 8103 manual[/link]
The pdf manuals are sort of hard to find on their site, so I would open it and save it first. They also have a paper copy for $7.95.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
