Will a FP-R127DF RX work with a PCM/PPM switchable FP-T5UAP
Can I use a R127DF receiver with a 1024 PCM FP-T5UAP transmitter. The TX does have a switch to select PPM or PCM. Can it lead to problems - and better off obtaining the FP-R129DP which I know works??
RE: Will a FP-R127DF RX work with a PCM/PPM switchable FP-T5UAP
I think I will just order a new FP-R127DF high band receiver (channel 45) to go with the Conquest FM Radio that came with the Great Planes Cub I just bought from a guy that had it almost finished but quit. He had the FP-R127DF Receiver (channel 25) installed but I think that is low band and installing a 45 crystal to match the ch 45 Transmitter might be a bad thing..
