Futaba 9C 5 point mix-Need trim
NC
I have created a five point mix on my Futaba 9C for two servos I use in a dual servo rudder push-pull setup. These servos needed to have their center, end-point, and mid-point locations trimmed in order to be synchronized, therefore, the five point mix seemed to be the right way to go. No way a Y-Cable or an external servo synchronizer could have done this for me. I use channels four and five for the two servos, set the sub-trim to synchronize the center points, set the end-points to synchronize the end of the throws, then use the five point mix to synchronize the mid-points on both left and right throws.
The result is a mix where both servos follow each other very accurately throughout both entire throws; this part is a success.
Unfortunately, it appears that the five point mix in the 9C does not allow for trimming the source channel. Therefore, trimming the rudder becomes a two step process. I need to use the sub-trim on both channels to do the rudder trim. No way I want to do this while flying, so, if anyone can tell me how to include rudder trim in this mix I have setup, I would appreciate it.
