spektrum problems
spektrum problems
hi i have just got a spekturm dsm for a hitec aggressor, when ever i turn it on it is intermiting on the reciever. its only intermiting when iam under shelter but when its on the track its fine. could it be because of the shelter its metal, or could it be my battery pack in my car.
My Feedback: (33)
RE: spektrum problems
Some of the antenna wires were routed wrong in the tx module from the factory and need to be changed. A lot of them came with the wire on top of the circuit board . Slowly take the cover off , check the wire to see if it is under the board . If not , remove the wire from the post on the circiut board and route the wire around the corner and under the top side. This is moe likely the problem , a few of us had the same problem and Spektrum told us to do that.
