Battery and setup questions (I'm a Rookie:)
WI
I have a cmp extra 300s 140 I'm putting together. I'm using 5 hs 625s and 1 hs 645 and I might put smoke on it too if its not to heavy. I am also running a evolution gt26 engine with electronic egnition. My question is how many batteries do I need and what is the best setup for this. Do I need a seperate battery for the ignition and servos+reciever? How big should the batteries be and wich is the best. Thanks everyone
My Feedback: (16)
GA
RE: Battery and setup questions (I'm a Rookie:)
You need one battery for the engine (ignition) and one for the receiver (RX&Servos)
Size depends on the kind of flying you are doing but I would say any pack that is at least 1000maH will be fine for both.
Contact Dave at www.radicalrc.com
He can hook you up with all your needs.
ORIGINAL: chadderbox
