spektrum
CA
spektrum
Hello all,
I just installed my new spektrum in my park flyer and I have a problem. The RX quits after a couple of inputs of ailerons (two servos). All other controls are fine (one servo per control). I noticed that the amber light on the RX goes out after a couple of rapid input of ailerons and then comes back in about 2-5 sec. The light remains steady with all other controls. I'm using hitec hs-65 hb's. I was using an airtronics radio on the same plane prior to the specktrum. please help!!!
thanks
thanks
KS
RE: spektrum
Greetings,
My guess is that you're overloading the BEC in the motor speed control. Try this: Plug in a standard 4.8v flight pack directly into the Spektrum receiver (you don't need a switch) and give it a go. I bet you don't have any problems.
Best Regards,
The Dude
Best Regards,
The Dude
