Where to buy connectors, pins, wiring for making servo extensions?
TX
Does anyone know if there is a source on the internet that will sell the connectors, pins, and wiring to make your own servo y-harnesses, extensions, and etc.
Jim
Jim
BC, CANADA
RE: Where to buy connectors, pins, wiring for making servo extensions?
Another source that I have used is Dymond Modelsport Ltd. Web site is http://www.rc-dymond.com/index.php?categoryID=36
Price and quality is excellent. They are not that difficult to do, but it does take a bit of practice using the hand crimper. Radio Shack sells one that is identical.
If you want to spend a few extra dollars you may want to consider this crimper. http://ashtekelectronics.com/store/s...tool-p-82.html
It apparently makes the job much easier. I have been using the Radio Shack one with good results. I do check every one I make with an ohm meter before using it. Hope this helps a bit.
Jim
Jim
