Know how to reverse HS-55?
Anyone successfully reverse an HS-55 Hitec? Would like to avoid a reverser if possible. Need 2 elevator servos-1 reversed!
Happy New Year! Henpecked Jim
My Feedback: (8)
KY
on most servos you reverse outside wires on pot then reverse wires on motor,call Hitec directly to see if the servo is reversable? Some of Hitec's servos cannot be reversed so you have to use a reverser.
It can be done!
It can be done, just reverse the two outside wires on the pot and the wires going to the motor. Be carefull though, the wires are very thin and do not like to be unsoldered and resoldered, use a low temp iron. Thanks!
