JR servos-Futaba receiver?
No Problem - if changing an existing Futaba servo to a JR servo you will need to flip the reverse switch on your TX.
Insert the Orange JR signal wire in line with the white Futaba signal wire. If servo is plugged in reverse, servo will not operate. (remove and plug in other way around, you will not have harmed servo or RX.)
refer to =
http://www.fatlion.com/sailplanes/servos.html
and/or
"Buddy Boxes. Servo Leads.Simulators.Interface"
at
http://homepages.ihug.co.nz/~atong/
regards
Alan T.
refer to =
and/or
at
regards
Alan T.
