Jr 652
Old 01-14-2003, 03:53 AM
BALSABRO
Default Jr 652
To all the JR fellows ou there Is there anyway of tighting the gimbals on this transmitter?
Old 01-14-2003, 04:12 AM
JohnBuckner
JohnBuckner's Avatar
Default Jr 652
Have you tried adjusting the gimble tension spring screws?
John
Old 01-14-2003, 05:38 AM
BALSABRO
Default how
wHERE ARE THE GIMBAL SPRINGS AND SCREWS (i KNOW PROBABLY IN SIDE)
Old 01-14-2003, 06:10 AM
MO_Radio_Tech
Default Jr 652
Remove back case half (six screws). On both gimbals, you will see brass colored tension adjustment screws. The screws pull down on the springs, putting more tension on the cantilevers, which put tension on the gimbals as you move them. The aileron, elevator, and rudder surfaces will be adjusted. The throttle has an adjustent on the ratchet for more tension (the BIG brass screw). There is also a non-functioning tension screw on the side of the throttle, in case the gimbal happens to be mode 1.
When you reassemble the radio, be careful to start the screws back into the original threads. Do not tighten past snug, the threads strip easy.
Old 01-14-2003, 06:17 AM
BALSABRO
Default thanks
mo thanks now maybe they won't be so senitive
Old 01-14-2003, 06:30 AM
MO_Radio_Tech
Default Jr 652
no problem, have fun flying
