recommended servos for a 26cc size plane ?
NJ
I am ordering a 1.00-1.60 2 stroke; 1.20-1.80; 26cc gas size plane and would like to know which servos some of you would decide to use . Keep in mind I fly outside of the box, meaning I will be attempting to do 3D with this plane.
Thanks for your tips in advance.
MO
RE: recommended servos for a 26cc size plane ?
I would suggest at least somthing with 100 to 110 in/oz an if you are doing 3d the faster the response the the better control i suggest you look at some manuf data sheets
AZ
ORIGINAL: kerwin50
QC, CANADA
I like Hitec 5925s for that size plane (130 oz and blindling fast). Maybe a 5954 (180 oz and quite fast) for the rudder. I would stay away of Karbonites with any gasser. I you decided on glow, then the 6965 would be the ticket. That is only because of vibration along with such a small plane that does not dampen the vibes too much...
NJ
For the price of the servos being recommended , my first scale plane will take almost a year to put together. The prices are high.
