Servo load testing?
Servo load testing?
Have you ever seen a load testing device?
I was thinking of a setup that would be cheap and allow you to cycle the servo under a moderate load.
I'm not interested in actual numbers, since many of todays servo's I believe have current limiting devices built in.
I'm just thinking that a small rig that you mount your servo into, connect a couple of springs in opposite directions from the servo arm and fix them at the other end, would let you apply a moderate load and then cycle it for a few minuets.
Add a degree wheel and a pointer maybe just to enhance the visual of the arm movement, and look for any gitters through the range of motion.
Does this sound like a pratical thing to do?
RE: Servo load testing?
You could set up a shaft with a control horn connected to the servo and another arm at right angles to hang a weight on. The servo would only be loaded in one direction but you could get a number on torque.
I have never seen a servo with current limiting and most modern high torque servos pull 2 to 3 amps when starting so be careful not to put too big a load on them.
Jim
Jim
