Elevator Reverser Futaba EXA6S
FL
I am running a y-reverser for my dual elevator setup on my 28% Yak.
1. One reason for doing this is that I need to have the channels linked together so that I can use the P-MIX on the transmitter to eliminate coupling while in knife edge.
2. I currently am not using channel 5, but since there is only one P-MIX I can not make an Elevator-Rudder Mix and also a Mix with each Elevator Half.
What have any of you done to overcome this problem with limited mixing? Besides the obvious "GET ANOTHER RADIO with more mixes!!!"
Any advice would be helpful.
