Futaba Super 8 Programing
My Feedback: (38)
WA
I guys !
Need help, to program channel 6 to switch G,to have a 3 position setting for my flaps.Switch in up position,0 flaps,center 15 degrees and switch down full flaps.Thanks for your help !
Gear-Up Charlie
Gear-Up Charlie
Don Edburg publishes a book on programming the Futaba 8u that is worth every penny. What you are trying to do is probably in the book.
You need to use 2 p-mix ...
Set OFS->FLP and then assign it to switch C in the position you want to.
I can't remember if you need 2 p-mixes with LINK ON or if you need 4 (one for each aileron).
I did it once for my UltraStick and worked perfectly.
My Feedback: (16)
GA
You will need to have three mixes. One mix to set the flap for 15 degrees (use offset), one mix for full flaps (use offset) and a third mix to turn off the channel 6 knob. (0%)
