jr8411 vs HS5945
Old 01-30-2003, 02:50 PM
Default jr8411 vs HS5945
What do you guys think? As far as I understand it the HS5945's would need to be programmed, which costs another 170$ for the programmer - which is the better way to go?
I'm probably starting a war here....
D
Old 01-30-2003, 03:08 PM
My Feedback: (506)
They are both good products. The Hitecs have an edge in that they have a more robust geartrain than the 8411s, are individually programmable, and cost less.
The programmer is not necessary for individual use. Its primarily used to set reversing, match deadbands, speeds and throw limits when you're ganging multiple servos to drive a single surface.
Old 01-30-2003, 05:50 PM
T_Hill's Avatar
The Hitec have a much longer lasting gear train. Being programmable makes it easier to match servos on surfaces with multiple servos. Yes you can match servos with a matchbox, but that's just one more component to fail. If you are setting up a 35% or bigger plane, the cost savings will pay for the programmer. I use mainly the 5945 for the gear train life, not because they are cheaper or programmable. I put 8411's in a new plane because I had them and now at 43 flights the gears need to be replaced.
Tracy Hill
Old 01-30-2003, 06:39 PM
Thx to both of you for the answers. My plan was to use 5945s (1 each) on the elevator and a 5945 in a pull pull setup. So I'm not really sure I'll need the programmer?? For ailerons I'm putting in 2 605s on each aileron, which obviously are not programmable. They are going into a 31% Giles....
David
Old 01-30-2003, 07:17 PM
My Feedback: (31)
t-hill
how does one know when their servos needs new gears. i don't want to run into the problem of like shocks that i end up getting use to ride as they wear out...
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
