Trainer cord, Spektrum to futaba 9C ??
Hi
I can't find a trainer cord for Spektrum to Futaba 9C (square connector) any where, does anyone of you know where I can get one[:@] ??
Regards
Fernando Viollier
Regards
Fernando Viollier
My Feedback: (29)
TX
RE: Trainer cord, Spektrum to futaba 9C ??
fdo300,
The Futaba square to JR phone jack may work. I read in Watt-Flyer that someone used this to connect a 9C to a DX6. does your DX-7 use a mono phone plug for the trainer connection.
Dave
Dave
Hi,
Apart from the physical difficulty of obtaining the suitable trainerlead, there is a much bigger difficulty to overcome : the difference in channel assignment.
Futaba, due to the transmitter sending the coded signal, uses on the output of the receiver the following channel assignment :
ch1 ailerons - ch2 elevator - ch3 throttle - ch4 rudder
however, JR/Spectrum uses on the output of the receiver the following channel assignment :
ch1 throttle - ch2 ailerons - ch3 elevator - ch4 rudder
So (assuming the 9C to be master) , when the Spectrum moves throttle (ch1), the coded signal goes to the 9C and is send to the receiver, where ch1 is used for ailerons...
For more info on that problem and eventual solutions to your problem, check-out my website (see signature) chapter 1, paragraph 1.6
But both transmitters beeing programmable-type TX, I am afraid that none of my solutions will be satisfactory.
The trainerlink from Horizon-Hobby can also change the channel assignment, but can only be used with JR/spectrum as master. Furthermore you will need an adaptorlead round-female-DIN to Futaba Square, which you will not find in shops
trainerlink : http://www.hangar-9.com/Products/Def...?ProdID=HAN173
Olivier
Olivier
Oliver
I will use the Spektrum as a master and the 9C as a slave.
The hangar 9 trainer cord has a round connector to DIN connector and I need a square connector at the other end.
Regards
Fernando Viollier
Regards
Fernando Viollier
Hi again,
With the Hangar 9-Han137 trainerlink and the Hangar-9-Han174 you have everything you need.
Han174 adaptor lead : http://www.hangar-9.com/Products/Def...?ProdID=HAN174
Han173 trainerlink : http://www.hangar-9.com/Products/Def...?ProdID=HAN173
Olivier
Olivier
