Futaba 9C wierd servo echo....uh...thing
Futaba 9CHP, R127DF, S2003, 6v 2000mah, CH26
On a new plane I have this issue where if I pull the right aileron stick and let it snap back, the right aileron bounces as if there was an exaggerated delay or signal echo. Left aileron is fine. I have a 24" non-heavy duty extension on the both aileron servos. Thoughts?
RE: Futaba 9C wierd servo echo....uh...thing
You most likely have a bad connection. Try connecting the servo directly to the receiver (yes, I know you'll have to temporarily relocate stuff). You should see the problem go away. Long leads and bad connections cause your difficulty. You may also need to go to a larger-diameter wire and get rid of as many sets of connectors as possible...solder where you must.
