Futaba Receiver Compatibility
NY
I have the 7 channel receiver that ships standard with most futaba 4 channel radios. I was wondering if I can just buy a 6 channel transmitter and just use the same crystal in the original transmitter. In other words, I'm trying to save money rather that buying a new radio system. If not what are my limitations? To be specific... I am looking at buying a Futaba T6XA transmitter. I can get one for sheap, I just dont know if it would be compatible. I believe I have the Futaba R127DF FM 7 Ch. Receiver. If they wont be compatible... Can anyone list some transmitters that would be compatible and can I get a copmputer transmitter? Thanks alot guys for all your help.
You can buy any Futaba FM transmitter and it will be compatible with your existing receiver. You should order the transmitter for the channel number you use and it will come with the correct crystal already fitted, no need to mess with your existing crystals.
Steve
Steve
