GPS Transmitter
GPS Transmitter
Hi all,
Anyone know of a system where GPS location can be transmitted wirelessly to a PC-based topo map?
I'd like to put such a device in a giant-scale glider, in order to know its location when ranging out to distant slopes in a mountainous area where it's difficult to judge distance to the plane relative to the terrain far below.
Any help / links appreciated!
GPS Transmitter
Yup,
Amateur radio operators do it . A GPS receiver is linked to a transmitter and the data is decoded by a PC and receiver at the other end.
If you are not an Amateur Radio OP you may have to use a transmitter on one of the license free bands,
I will try to find a website for you with more info.
NY
GPS Transmitter
You're going to pay WAY WAY too much money for a commercial product, I know I've looked. This can't be done very easily with commercial equipment because FRS radio would have to be rigged to transmit continuously and this usually fries them in a hurry, they're not designed for 100% duty cycle. If you want a reliable link you're going to have to dive into the deep end of electronics, or find someone that can build it for you for a decent price
GPS Transmitter
Originally posted by Lynx
The range on those things is pathetic.
I had a GPS setup going for over 2 years and no problems at all.
Also the FRS radios will run 100 duty cycle.
The final amp is built inside the thin poly antenna and that never even gets warm and I have the 2 watt version
GPS Transmitter
Ladyflyer, Whirley - Did your systems display lat/lon coord's or a moving dot on a map? Although I'd prefer the latter, a display of simple lat/lon coord's is good enough. On that note, can you provide any hardware details, incl. brands & p/n's, or were your systems custom-built?
Some products I've seen on the net look like they'd do the trick, especially the stuff from http://www.u-nav.com Also, some higher-end systems that might find r/c model or UAV application from http://www.vetrak.com./
GPS Transmitter
Originally posted by wildblueyawner
Ladyflyer, Whirley - Did your systems display lat/lon coord's or a moving dot on a map? ./[/URL]
The setup I had just showed the dot.
But I didn't have the system I thought you thought I had.
The way my setup worked was when I transmitted the person at home had the topo map software in his laptop for the geographical area I was in.
He saw NOTHING intil I transmitted then a dot would show him on the screen where I was located. We live in a push button world today but I still track out with a compass and a topo map.
I never did get involved with the video part and don't intend to because I use my setup for land navigation instruction only, then resort to map and compass.
Your going with RC control and it's an area that I really have no real knowledge of.
Someone here must be much more qualified to answer the questions you have related to GPS/RC/Video
GPS Transmitter
. . . when I transmitted the person at home had the topo map software in his laptop for the geographical area I was in.
GPS Transmitter
Based on that, I presume that whatever you were equipped with would be too large or heavy for installation into an r/c plane? (keeping in mind that I'd be installing this stuff into a giant-scale glider).
Well i'm a ham radio OP so I had a small 440 mhz HT that gave me 5 watts out.
Not that much weight at all but if you put it in the plane who's going to key up the TX?
The plane will not carry that much weight.
Most of the heavy stuff in on the receiving end on the ground.If you can be a bit more Specific then maybe I can help you out.
As I see it now you want to track the plane from the ground when it's out of sight
GPS Transmitter
. . . who's going to key up the TX?
To put this in perspective, this glider (currently in process) is rather large ==> either 8 or 9 METERS wingspan, so it will be visible from a great distance. What is difficult, given the scale of the surrounding mountain topography, is judging how far the plane is (horizontal distance) relative to features on the ground far below it (which, in this case, can easily be a thousand feet down). In other words, "what terrain is the plane flying over right now?" Flying an r/c model amidst high mountains is one situation where a plane's distance away can be seriously overestimated, i.e. it's a lot farther to that ridge than it looks.
GPS Transmitter
[i]. [/B]
First are you a ham?
If not then what are you considering for transmitting?
You need a receiver that will be pick up the sig then that sig goes into a TMC box that will feed and deciper the carrier.
Other things you need to consider is to make sure the on board TX does not blanket out the RX so I would use something in the UHF range.
The FRS radio units will work and you can open them up and reduce some weight by just having the TX board exposed and a small switch to power it up.
I know a local ham who hits this RCU site when he feels like reading and this Guy has to be an experet in this area because thats all he does.
I'll try to get him on the repeater today.
Your not looking at much $$$ for what your doing.
I'll PM you later
GPS Transmitter
Glider position
This is an interesting question that you have raised. I do the same kind of cross country scale glider flying and we have often wished for such a system. However, in the UK it was illegal to transmit from an airborne object until,very recently.
A couple of alternative suggestions. I know that you can get relatively light small and low cost video systems that could give you a real-time picture of the terrain below. (or in front!)
The alternative route I have chosen is to fit a Variometer. It does not help you know your position over the ground but it tells you if you are in lift or sink which is what you really need to know, and your altitude, and your battery condition.
What it also taught me was that I am not as good a pilot as I thought. I was pretty sure that I could centre in a thermal accurately but the vario tells a different story! It makes you fly better.
Regards,
John.
Regards,
John.
GPS Transmitter
He just sold a full station last week on the local repeater for $250.00 but it was setup on the ham bands.
I should be able to contact him tonight and will PM you the info
My Feedback: (30)
GPS Transmitter
You can solve your problem if you are a ham using a hand-held gps unit, video text overlay board, small camera and a ATV transmitter with 100 mw power on board the glider and receive the signal using a cable ready tv set (small battery powered Black/white works great).
The ATV transmitter can either be in the 420-440 mhz band, 900 band or the 2.4 gighz band. Source for both the txs and video overlay board is PC Electronics or Videolux . Cheap b/w cameras ($20) are available from super circuits (do a google search).
The small camera generates a video signal, the video overlay board overwrites the GPS information(gps coordinates, ground speed, altitude, zulu time) on the video picture and the ATV transmitter transmitts the signal. The best antenna on the glider is a simple dipole mounted vertically in the tail.
The cable ready tv receives on cable channel 58-60 depending on the frequency of the signal(420-440 mhz). The higher frequencies require a downconverter.
I hope this helps. I use this set up in many of my research planes.
Elson
Elson
GPS Transmitter
Originally posted by rc bugman
Elson
Elson
But I think he can use the FRS transmitter.
Where did you pick up a 2.4 GIG system?
At that frequency things get critical and the antenna is to short for a dipole configeration.
How about filling us out on the name and how you hooked into the GPS.
Also what GPS are you using?
My Feedback: (30)
GPS Transmitter
All the equipment I use is off the shelf and runs at either 420-440 mhz or 910 mhz. It would be far easier to just study and become a ham at the tech level and then you can use all that neat off the shelf stuff.
I believed I had to study about a week to pass the test and I am a bug person, not an electronics buff.
Elson
K2BUG
Elson
K2BUG
GPS Transmitter
Elson
K2BUG
Elson
K2BUG
Thats all he really needs then he has it all with no problems.
My extra was 50 questions.
I think the tech is only 35.
I shot for the extra just so I could work the DX CW on lower part of the bands.
Really have no use for a MIC except when operating VHF & UHF
Neat call you have there.
AF2Q
GPS Transmitter
Originally posted by Ladyflyer
We had a 5th grader pass the Extra class exam after studying 2 weeks cold turkey !
The new multiple guess questions are VERY easy to conquer .
I think the tech is only 35 questions also and you only need a 76 to pass.
I think i'll send that person a PM and let him know he can take a practice test on QRZ.com
NY
GPS Transmitter
Did that fifth grade pass the code exam? =) It's required on the Extra. Keep something in mind. The FCC is required by their own law to publicly make available the question pools for the tests. That means every question you could possibly face is available out there.
