12z throttle cut
SD
12z throttle cut
Being new to the 12z I have a question on throttle cut. I noticed that if you program this function and one might accidentally bump the switch you loose throttle control if you should bring the throttle down to the range of activation. If you remember to turn it off throttle will come back after a short delay.. The 8u and my 9c didn't have this scary feature. One could put it on the trainer sw. but I some times use this. Anyone have any suggestions. Thanks a bunch JK
RE: 12z throttle cut
I'm like BR289, I have mine on the C switch (B switch on the other side). Only reason I've done that is on the 9C it is the only 3 position switch on the front. That way my 9C, 9Z and 12Z all have throttle cut on the same switch at the 'last' position. I have yet to bump either switch.
Addtitionally, here's a link to a thread "12Z and Logic Help" seems to me you can enable a safety switch.
http://www.rcuniverse.com/forum/m_6383167/tm.htm
Good luck!
Good luck!
