Xtreme link in your 9Z WCII? Have fun pulling old antenna!
RE: Got my XPS, now how do I get my 9Z antenna out?
ORIGINAL: Dustflyer
Anybody know how to get the antenna out of a 9Z WCII transmitter? Tried to unscrew it but apparently it doesn't come out that way.
Why don't you just collapse the antenna inside the TX and forget about it? Or are you supposed to remove the antenna entirely? Anyone know? With the Futaba modules, I have read you just collapse the original antenna inside but that is Futaba approach.
Woodie
TN
RE: Xtreme link in your 9Z WCII? Have fun pulling old antenna!
Its not that difficult to take it out as long as you dont intend on putting it back in. Then you will have to take the back case off.
http://runryder.com/helicopter/t1265...ove+9Z+antenna
My Feedback: (10)
TN
Make sure you disconnect the battery before messing with the antenna. I've fried a radio before while taking the antenna out - the metal antenna touched something that cost $75 and shorted it out.
VA
Here is what I recommend if you ever think you need to put the original antenna back.
Get a wooden dowel the same diameter as the thickest segment of the antenna. Tap a 3mm bolthole on the bottom.
Remove antenna iaw above posts and slide in the wooden substitute. Cut dowel leaving 1 inch sticking out the top of the TX. Attach bobble head figure to wood stub.
Fritz
Fritz
My Feedback: (16)
AZ
If you remove the battery door, you will find a 2.5mm screw that can be removed and then out comes the antenna.
FCC requires that we tell you to remove the antenna. Whether you do that or not is up to you.
ORIGINAL: JimDrew
KS
ORIGINAL: Silent-AV8R
Huh?? So are you now saying that it is only a legal CYA that makes you recommend that the antenna be removed?? Or is it actually required?
ORIGINAL: JimDrew
Can't really answer that now can he? Wink wink nudge nudge say no more
My Feedback: (36)
ORIGINAL: JimDrew
ORIGINAL: JimDrew
dave
