Sanwa RD 6000 Super
Sanwa RD 6000 Super
Hi Everyone
New to the helicopter hobbie and Just bought a Sanwa RD6000 Super radio, in mode 1 can anyone tell me if it can be converted to mode 2 as all members of my club fly mode 2 or does it have to go back to the manufacturer
BC, CANADA
Sanwa RD 6000 Super
Hmm... I had a quick flip through my manual...I'm assuming that there are no big differences between the radios sold either side of the pond(except frequency?) .... I can't see any mention of how to change modes from one to the other... I'm thinking this is going to need either sending it back to the manufacturer or someone with a lot more radio know-how than me!
RE: Sanwa RD 6000 Super
as stated by another member on another forum, by cubanflyer
How to change the mode on Sanwas radios.
Thanks to David from Glasgow for this information.
Sanwa Mode 1 to 2 change via service mode
1. Switch the radio off.
2. Shift the left switch forward.
3. Hold down F.Mode and End.
4. Switch the radio on.
5. Flip back the left switch.
6. Scroll down to MOD.
7. Select mode 2.
8. Press End.
9. Switch the radio off.
10. Switch the radio back on.
1. unscrew aerial
2. remove all screws from the back
3. carefully lift the back off BE VERY CAREFUL AS THE TRAINER SOCKET WIRES
ARE SHORT AND SNAP EASILY
4. remove the spring / tensioner and seesaw assy from the elevator stick
5. remove the throttle ratchet asembly and stick travel limiters
6. refit to opposite sticks without the limiters
Re asemble the tx
1. With the radio off.
2. Shift all switches forwards / down .
5. Wait for a beep
6. Flip back the top left switch.
7. Release F.Mode and End.
8. Scroll down to MOD.
9. Select mode 2.
10. Press End.
11. Switch the radio off.
12. Switch the radio back on
SVC menus
Init-->YES (press yes button)
CH---->yes button selects 6 or 8
NEU--->sets neutral stick positions
TRV--->sets stick calibration
A/D--->VR1....VR6 stick pot values
MODE-->mode 1 or 2(stick orientations)
LCD--->All led's lit, some, some, none
SW---->press 'yes' to see switch positions
B*AL-->use +- to set batt voltage alarm
PULSE->Nor, LO, HI
V*Cal->'+' set voltage to 10.0 volts
All-CR>All clear
HTH
Cubanflyer
7. Select mode 2.
8. Press End.
1. unscrew aerial
Re asemble the tx
5. Wait for a beep
9. Select mode 2.
10. Press End.
SVC menus
PULSE->Nor, LO, HI
All-CR>All clear
HTH
Cubanflyer
Hi,
has anyone tested this manual? My problem is, that I do not know what is meant with left switch. On the left side are so many switches that I do not know which I should use. Since I can reverse the directions of the switches in the settings, there are so many possobilities that I cannot try every without getting much older
Pomdas
Pomdas
Hi
Just to hightlight the switches there is another switch involved. I have made the changes
2. Shift the left switch forward. (Flap-Flight mode away from you)
2a. Switch AL D/R to '0'.
7. Select mode 2.
8. Press End.
1. unscrew aerial
SVC menus
PULSE->Nor, LO, HI
All-CR>All clear
Hope that makes if clearer.
Cubanflyer.
7. Select mode 2.
8. Press End.
1. unscrew aerial
SVC menus
PULSE->Nor, LO, HI
All-CR>All clear
Cubanflyer.
Hi again,
it looks that I make something wrong...
Here is what I do: I switch the Switch named with Retract gear (in blue) and Flight-Mode 3 (in white) to the back direction of the radio. Then I press the Buttons named with F-Mode and End simultanously and switch the radio on. The switch named with al D/R (in blue) and C-Mix (in white) is switched to 0. Now (while still pressing the two Buttons End and F-Mode) I switch the Retract Mode/Flight-Mode 3 switch back to the front direction of the radio (to my body).
Till yet there is now change in the display. So I think that there is something wrong... Could you help me?
Thanks again
Pomdas
Thanks again
Pomdas
Hi
I have checked the switches in the manual for my set and the are actually the opposite way around on my set.
Set the 'flap' switch to the rear & the 'AL D/R' before switching on the radio.
When you have switched the radio on let go of the 'F-mode' & 'End' buttons, before trying the next step, you should see 'svc' on the screen.
How is the left hand switch named on your set? (mine is flap)
cubanflyer
cubanflyer
Hi
my set looks exactly like the the one which is described in the manual on this page (no idea if there are different ones): http://www.airtronics.net/RD6000_Super.htm
So on the left side are a two position switch called Retract Gear and Flight-Mode 3 on the upper side, a trainer button, a two position switch called El D/R and C-Mix 1 and a two position switch called C-Mix 1,2/AL-RU Mix.
On the right side is (from left to right) a two position switch called Al D/R and C-Mix2, a button called Throttle Cut and a three position switch called Flap/FL-EL Mix and Flight Mode 1,2.
Oh, now I got it... I put my right switch in the middle position and then I pressed the two buttons while switching the radio on. Now the display is clear and I only have to switch the right switch to me. So if anybody have had the same problem, he will maybe have the solution, now.
Thanks cubanflyer !!! I did not know, that the switches are in a different order in different product types. Now a final question: Does the order of the buttons change when I change the mode? Since I own a mode 2 version of the RD6000 Super and want to change to mode 1 (sorry, if this was important for you, because I did not give this information to you earlier), this could be important...
Pomdas
Pomdas
Dear all concerned,
I had changed modes of all my friends, and myself who had the Airtronics RD 6000 super , I had no problems doing the procedure you posted i all were 72mhzs. all were bought from Japan by my friend who owns an RC shop
i encountered another friend's radio which he bought from Hong kong and was same model RD 6000 super with 8 model memory 35Mhz. but it was Branded Sanwa in place where the airtronics brand emblem is located. Though I know they are the same company, my question is this. when I changed the mode of the sanwa rd6000 super from mode 1 to mode 2. the radio's memory shifted only to 4 model memory. whats worse is that the functions trims have somehow shifted to the capabilities of a RD6000 sport ( which i verified thru a down loaded manual of the sport).
Could anybody help me on this?
My Feedback: (13)
LA
I am one of the unlucky guys that learned on a mode1 SO I am trying to set a mode 2 in to a mode 1. When going in to settings it looks like the TX is keeping the mode 1 setting the only thing I am getting a ERR2 code. Can someone help me? Please! Lol . I may have change something some where. That I should not have. Thanks
Hello
I see you had the same problem as I have with Sanwa RD6000 transmitter showing ERR2 basic
Did you find a way to cure that and get it working correctly
Cheers
Peter
Cheers
Peter
