I think I fried my radio!!!
My Feedback: (36)
I have a JR XF631 that was working fine earlier today but after I charged it on my new Hobbico accucycle for approximately an hour and a half, The radio would not power up. Charge settings were 8 cell/ 50mA charge rate on the 9.6v cell 600mA battery . The new charge leads have the JR tag on them and I do not believe I had them plugged in backwards (red/Black). I would think that the charger would not register that it was charging if the poles were reversed
I hadn't planned on charging the batteries for long and the voltage was at 8.8 when I hooked it up to the cycler. No discharging was done at the time. The battery registered above 9.0V when I checked it afterwards. Still no power to the radio
I am by far not an expert when it comes to electronics so did I do something wrong? What are JR's poles for the charging jack (positive inner/outer?) .
Worst case scenario did I fry the radio or is it a simple fix.
Help please.
Thanks!
Help please.
Thanks!
My Feedback: (36)
Yep that's what it appears to be.
Fuse was blown. The radio was still charging after about an hour or so. I didn't turn the cycler off when I removed the leads. Will replace it and mark another red check in the "Lessons Learned" file. I don't know if I should send it in just in case. I will contact JR or Horizon to be sure. Would hate to see my toys do a power fall from the sky~!
Thanks for your advice LadyFlyer!
