Cirrus Servo Arms?
Cirrus Servo Arms?
Will Futaba servo arms fit Cirrus servos? I know JR, Airtronics and Hitec do not work. I do not have any Futaba gear so I can’t check to see if they fit.
RE: Cirrus Servo Arms?
Naa, Naa, Pa Ben, the servo mfg's have not standardized the number of splines on the output shafts yet which makes the modeler have to use only their arm and wheel selections. There is the possiblity that Du Bro makes arms that will fit the Cirrus servos. I have used only a few Cirrus and Tower servos mostly on throttle controls. Have found the Hitec servo wheels to small of diameter for getting aileron differential, and had to use Futaba servos with their large drive wheels to get the deflection I wanted. Sometimes this means I have three different mfg's servos in a model.
Rich S.
Rich S.
