Ignorant receiver ?
Ignorant receiver ?
On an 8 channel receiver, the battery is plugged into ch. 8. Doesn't this make it a 7 channel receiver by taking up the eighth spot. I've never filled up a receiver, but was curious.
RE: Ignorant receiver ?
You can actually plug the battery into any of the slots. Likewise, you can use a Y cable and plug both a battery and servo in the same slot.
Don
Don
My Feedback: (89)
[8D]By placing a Y connector into the 8 Channel and feeding the battery pack on one side and a servo on the other side it becomes an 8 Channel receiver. You can feed the battery on Channel 1 or any other Channel with a Y connector.
Codimasta
AMA 11269
Codimasta
AMA 11269
One caution when plugging the battery in through a Y connector; be sure that it is heavy gage wire as all the current for all the servos and the receiver must pass through that one thin lead and even 22 gage wire may be marginally small and many Y's are smaller gage.
