tryin to run 2 ele servos with a sx600 rad
NJ
whats the easiest way to run 2 elevator servos out of 1 port
do i flip 1 servo
can my radio mix the 2
i dont want to buy a rev servo
thnx
do i flip 1 servo
thnx
My Feedback: (89)
RE: tryin to run 2 ele servos with a sx600 rad
A simple method is to use one Futaba & on JR servo....plug it into a Y harness, then plug it into the aileron channel. This works great if you have the servo's mounted to the back of the fuselage....The JR servo operates in reverse of the Futaba servo. Or you can buy a servo reverser from Horizon...Expert brand ...very reasonable..
Codimasta
AMA 11269
Codimasta
AMA 11269
