antennae
TN
antennae
is it true that you're supposed to have your antennae pointed straight up at the sky for 2.4 or can you just leave it straight up out of the transmitter?
RE: antennae
Hey "g". Follow my trend posted about an hour before you posted the same question! Probably vertical if my radio theory is still good!
You can follow a similar posting from the RCMF at:
http://www.rcmf.co.uk/4um/index.php/topic,45068.0.html
cheddar-caveman
cheddar-caveman
RE: antennae
Hey guys,
I'll vote for the vertical polarization, in fact if I were using 2.4Ghz in a glider, where you tend to be very high overhead, I would have it back past 90dg. pointing to a spot in the sky directly inline with the "solar panel" I usually keep a "lid" on
Cheers,
Pete
Cheers,
Pete
