12FG
My Feedback: (98)
12FG
I have the problem of my rudder is somehow linked to my throttle. When I input a right rudder command by moving the stick to the right, it causes my throttle to retard. When I move the rudder stick to the left , my throttle increases. It's only a small mount, but it is causing my turbine to go into failsafe mode. I have checked all of my mixes, and have them all inhibited. It is doing it on all my planes stored in the TX. Which some are prop planes. Can someone help me fix this?
Doug
Doug
My Feedback: (10)
RE: 12FG
I would suggest doing a reset of all data for one of the models. You will have to reprogram, but that may be the only way to find out if you can clear it.
My 12FG has not exibited that feature
Jeff
Jeff
RE: 12FG
Hi Doug,
I know this sounds a bit basic, but are you using a smooth throttle rather than the ratchet? Is it possible you are actually moving the throttle stick a little, that is if you are flying mode 2. Maybe too high spring tension on rudder with too low tension on throttle.
Now I assume that the 12FG has a screen that shows servo movement as bar graphs, like the 9C does, that may help to sort it out.
Good luck and let us know what you come up with.
Pete
Pete
