HDX Full range receivers
hellow i have futaba 9z synthetized, and i like have the HDX Full Range 6CH Digital Dual Conversion DSP Receiver 72mHz. this receivers function with my radio
GA
RE: HDX Full range receivers
It is not likely that it will work with the Synthesized Module. I have tried an FMA M5 and it does not. The reason (On the FMA) is from what I understand the Futaba synthesized module "Pulses" differently and many receivers cannot understand it. On the other hand, if you still have the non-synthetized module just plug that in and they should work fine.
