Crystals
Old 04-04-2003, 01:46 AM
Default Crystals
Is there any problem trading out crystals for like manufacturer receivers. Ex: I have a 6ch jr rec. with a crystal that I want to take out and put to the jr 955s. Any probs.
Thanks in advance.
Old 04-04-2003, 01:52 AM
Default Crystals
It's fine as long as both are single conversion or dual conversion. I am not familiar with JR's receivers.
A dual conversion crystal in a single conversion receiver (or vice versa) will not work. Also, stick to crystals of the same brand as the receiver, as you alread mentioned.
Old 04-04-2003, 02:26 AM
Default Crystals
Thanks.. The receivers do not mention anything about conversion, but one is FM and the other is spcm. Does that matter.
Old 04-04-2003, 02:33 AM
Default Crystals
I don't think so, but please don't trust me on this one - as I said, I'm not well versed about JR equipment.
I suggest you resubmit this question in the JR forum: http://www.rcuniverse.com/forumdispl...forumid=174&s=
Old 04-04-2003, 02:40 AM
Default Crystals
I was just reading another thread, and it seems that the R945 and R940 are the only dual conversion receivers JR makes, and all others are single conversion. As far as I know, the encoding method (PPM / PCM) makes no difference to the crystal.
A quick range check after swapping the receiver crystal is always recommended.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
