32MB Flash Card for 14MZ/12Z
My Feedback: (24)
Regarding the 32MB Flash Card (for the FUT 14MZ/12Z) that is needed to perform the software update (to go to 2.4) ..... The Futaba version of this card (from Tower Hobbies) is $ 79. Will any 32MB Flash card work ? ..... like the ones availble in local stores for about $ 25 ? Thanks. Bob
My Feedback: (7)
FL
RE: 32MB Flash Card for 14MZ/12Z
They dont all work, I had one that didnt but three others that did. I have a 2.0 gig sandisk extreme III that works well. It gives it a 15,000 model memory.
You will just have to try out the one you want.
good luck
Paul
good luck
Paul
CO
Not all CF cards are the same. they use different controller-memory IC's inside that have a VERY WIDE range of performance in both rd/wrt operations.
We are taking like ~5-7mb to ~20mb xfer rates, depending on brand and speed grades.
Use a CF with a 50X speed rating if you are up to the challenge.
As Futaba puts it, warrany may be void. Disclaimer.
Where I work we use lots of CF cards and there is definately a difference.
