single channel supporting 3 servo's?
i'm using
[link]http://www.spektrumrc.com/Products/Default.aspx?ProdID=SPM1200[/link]
the spektrum reciver and i was wondering if the steering channel will be able to support 3 servo's or if it will fry the reciver.
im planning on using a y-connector and a reversing y- connector
RE: single channel supporting 3 servo's?
That is a question you could ask Horizon for a definitive answer. However, I have operated with no problems an airplane with three analog servos on one channel using y-connectors.
I don't have the spectrum, but I have 4 high torque high speed digital servos on one channel with a futaba 2.4 ghz reciever. Although it was through a matchbox.
Good luck!
Austin
Good luck!
Austin
