Fm Receiver & Pcm Receiver Crystals
AL
I have several Futaba R127DP receivers all in the low channel range and a new Futaba 6XAS transmitter which is selectable for ppm/pcm, also in the low channel range. I will need to change the crystals in the pcm receivers to match that of the transmitter. My question is: Are the crystals in an FM receiver the same as the crystals in the PCM receiver as long as they are both dual conversion? I am so glad to see Futaba finally offer receiver crystals in singles rather than a matched pair for both tx & rx.
***********Thanks In Advance For The Help**************
My Feedback: (8)
Look into the crystal ball....
There is NO difference between PPM and PCM crystals. You just need FM dual conversion crystals.
Check your e-mail for a guy that does crystal swaps.
