Hi-Tec SuperSlim - will it work?
My Feedback: (9)
I have a hi-tec superslim rx for JR. Can I make this rx work for a Futaba tx? I have a different rx for JR that has a wire that can be moved for JR or Futaba but the SuperSlim doesn't appear to have this. Do I have some options?
Dan
Dan
No your SuperSlim that was intended for Jr Tx will not work for your Futaba Tx unless your Futaba Tx has a shift selectable feature
Futaba and Hitec uses negative modulation shift.
JR and Airtronics uses positive shift
Tx and Rx's that are not of the same shift are not compatable unless either the Rx or the Tx has a selectable shift feature. The other Rx you have is probably the shift selectable Hitec But the Superslim is not selectable however can be ordered in either shift.
John
John
